Here we go again - iChlor30 problems.
Charlie227
83
Vero Beach, FL
Last October we converted our pool to salt and had an iChlor30 installed. After only a few months, the flow/sensor switch was replaced 2 times and then the unit started leaking. Pentair replaced the unit.
The new unit Is only a few months old and has had it’s switch replaced once already.
This morning on power up, the unit is flashing a red low salt light and there is no display at all in the output display window. It also won’t enter the diagnostic mode. It was only a red salt light last time. So is this another bad switch or something more?
Time to call Pentair for a work order.
Should I be thinking of another type/model as a replacement or do all SWCG’s have these continual problems?
ajw22
8,818
Northern NJ
The iChlor model is Pentairs low cost response to their higher cost Intellichlor cells. The quality may not be in the lower cost product. The Intellichlor has its issues with bad flow switches and they are easily replaceable. So hard to say if you just got a lemon.
If you asked me I would have advised getting an IC40 instead of a iChlor30.
Reactions: Charlie227
setsailsoon
1,371
Stuart/FL
Sometimes the pump or automation with same manufacturer enables more features. If this is the case with your system just be sure you're OK giving that up. Sounds like Pentair is standing behind their product though and generally they seem to be fairly well-respected. In my case I have Jandy equipment and controls but the benefits were marginal (% power control on my phone). I found several disadvantages I didn't like with Jandy so I went with Circupool after market based on it's reputation from many owners, $/lb Chlorine, and warranty. It's only been a few months but I'm thrilled. Error free operation since day 1.
Hope this helps.
Chris
Charlie227
83
Vero Beach, FL
I’ll checkout the IC40 and see what I can do. Thanks.
mknauss
21,961
Laughlin, NV
It is direct sun most of the day from say 10am to 3pm. Should I cover it?
The control electronics for Pentair SWCG's are in the cell. No matter what, it is not good for those electronics to have a hot sun beating down on them. Does the iChlor have the power unit integral or is there a separate power unit?
Charlie227
83
Vero Beach, FL
There is a power box on my wall and a power cord to the SWCG
Reactions: mknauss
Charlie227
83
Vero Beach, FL
Pentair replaced the unit under warranty this morning. I put a pump motor cover over it to protect from rain and sun. We'll see if that makes a difference going forward. Thanks for the tip Marty.
LgHorn
Active member
Nov 21, 2016
39
Cedar Park, TX
I just installed an iChlor 30 this past weekend. I'm hopeful I don't experience the same issues, but it does sound like these models do have some problems with the flow sensor (similar to the Intellichlor models), but also some reports of the control unit or LEDs going out. I installed it myself so I won't have the longer term warranty coverage from Pentair. So far it appears to be working OK, but I'm going to keep an eye on it often.
Mine is also in the sun for hours a day in the afternoon so I'll try to come up with something to help protect it from the blast of our Texas summer sun & heat.
Charlie227
83
Vero Beach, FL
Although Pentair does not specifically say the unit needs to be under cover, I put a pool pump cover the new unit. We’ll see.
Reactions: LgHorn
