Help with Pump and Filter hose leaks
Ryfq
3
Hendersonville, TN
Hello all. First post, although I've been a member for a few years. Love this site. Graduated from Intex pools this year to a "real" above ground pool. Installed everything ourselves thanks to lots of reading through forums on this site and beyond. We have a Hydrotools pump and cartridge filter combo (model#71906). Followed what instruction there were with the pump to the letter (Teflon tape on all screw-in/ screw-on fittings). It seems we have leaks at almost every connection. I'm planning to try to re-tape all of the screw connections, but I'm a bit baffled by the hose connections. There are no gaskets of any sort. It's just plastic hose connecting to PVC by hose clamp. All of these connections are leaking and it makes sense logically that they would. But it seems from my research that most people do not have this problem. What am I missing? What should I do differently? Thanks in advance!
Ryfq
3
Hendersonville, TN
Welcome to TFP! :wave: So the instructions said to use Teflon tape. How many wraps did you apply to each threaded fitting?
Thanks for the reply. The first round, I did 3 layers. The second round, I did 2 layers. It seems improved, but still a constant drip from the largest connection between the pump and filter.
Update: I stole some rubber washer rings from our old Intex system and used them on the gray hoses. This got them to stop leaking, but I still wonder if I'm missing something. That shouldn't be the answer...
jcp
261
Mid Missouri
On the hose clamp fittings, assuming you have the hose and clamps positioned properly, you just need to get a nut driver and really tighten the clamp up. I think it would’ve been hard to get mine tight enough with just a screw driver.
I used Oatley Great White sealant on my threaded fittings, I still had a little trouble getting them to seal. I was scared to over tighten them, but a good turn after fully hand tightened did the trick on all but one. Had one on the suction side start a slight leak again after vacuuming, going to give that one another 1/4-1/2 turn tonight and hopefully I’ll finally be done.
Ryfq
3
Hendersonville, TN
Thanks everyone. I may try the sealant on the threads. My plan is definitely to hard plumb everything soon. But wanted to be able to get things going in the meantime. Once I get around to the plumbing, it will be a about a 40 foot run of PVC. Is 2" PVC overkill for my setup? It's a 1.5 HP pump.
