Help with Jandy JXI Heater High Water Temp Fault
Teduardo02
4
Montgomery County PA
My Jandy JXI gas heater wont fire up because it thinks the water temperature is too high. I ordered a replacement water temp sensor online and just replaced it but it still thinks the temp is 142 F. I tested the new sensor with a multimeter checking the ohms and it reads properly. Where should I go from here? Thanks to everyone in advance.
Teduardo02
4
Pics of the equipment? Sounds like heat is backing up in the intake side of the manifold. Does the heater have a versa flow? And the 1.5 Pentair pump is single speed?
Here are some pics. I think its a single speed pump and not sure about the versa flow. Sorry I just bought the house and still trying to getting to know how everything works. Thanks
ajw22
41,343
Northern NJ
Pentair Intellichlor IC-60
I wonder if the 10k resistor test would work on the jxi. Let’s ask Allen @ajw22
It would but he said he tested the thermistor with a multimeter and it had the expected reading.
There is a thermal regulator and bypass valve in the header that I would check. See page 12 in Workbook JXi Pool&Spa Heater that is a training manual for pool repairmen.
ajw22
41,343
Northern NJ
I actually said the same thing before I edited it above. The heater never initially fired so his reading 147. The resistor test would rule out board/thermistor.
I thought the heater ran like you did.
Connecting a 10K resistor in place of the thermistor will determine if it is the problem is in the wireing or board which it sounds like it is...
