I purchased an Intelliflo 011028 online and am trying to install it. It went pretty good except I got the power to it and ran the communication 485 cable to an Easytouch 8 but it does not show since I can run the pump by the scheduler on the pump timer . I am replacing a Whisperflo single speed. I cancelled all the timers and created a new one. I selected intelliflo vs on the Easytouch . I set a timer to see if I could get it going but nothing. Then noticed I could start from the pump indicating the communication isn't working. The pump is running fine from the keypad. The old pump was set to a a relay which I unwired and wired direct to a breaker. Does the jumper to relay 1 need to be disconnected even if there is nothing wired to it? Any help or ideas are appreciated'
