Help with first TFPC calculations vs Pool Store recommendations
nappi.rachelk
6
Utica, NY
Hi all. I'm waiting for my test kit to come so we are relying on the pool store test for right now.
Our pool cover had issues so the pool was very dirty. We got a great robotic vacuum and it's looking great, but it won't be for long. I'm on a trip and my spouse dumped powder stabilizer in, but I imagine it all got vacuumed up. As a result here are our levels:
Test Results 06-06-2022 @ 09:15 AM
Free Chlorine: 0.1
pH: 7.2
Total Alkalinity: 113
Calcium Hardness: 167
CYA: 22
(This is a 33000 gal inground vinyl pool)
Pool store told us to add Balance Pak, then also wanted us to do a bunch of powder shock or 5 gallons 12.5% liquid chlorine, and 1 gallon liquid stabilizer. This seems very wrong to me.
Question, because our FC is 0.1 and our TC is 0.1, do we go ahead and SLAM? If not, what order should I fix things in? My instinct says pH/TA, then CYA, then FC. But I'm very new to TFPC and looking for your advice. We went with pool store recommendations last year and it was a disaster - mustard algae, constant cloudiness, putting in lots and lots of money... so I'm glad to be on the right track now.
AK-
963
Northwestern NJ
CircuPool RJ-30
Welcome to TFP!!!
There is not much that can be done based on pool store test results as they aren’t considered reliable (try taking a water sample to 4 stores you will likely get 4 different results).
While you wait for your test kit use PoolMath to add 5ppm of LC (Liquid Chlorine) every evening. This should slowdown algae growth.
Once you receive your test kit them we can help you if the SLAM Process if necessary.
IceShadow
4,189
Milwaukee, WI
You can't rely on pool store tests and we really can't advise on them as they so often turn out to be just wrong. If we have you add something like CYA and it turns out the pool store test was wrong and you had a lot in there to start with you could end up draining water.
You do want FC in the pool. How does the water look now? If it's clear, add about 3ppm each day until the test kits arrives. If it's cloudy or green, add 5ppm each day. Liquid chlorine is recommended.
Once your test kit is there, post your full results along with info on how your water looks so we can assist. It also helps if you fill out your signature - you can see mine as an example. If you're on a mobile phone, turn it sideways to see signatures. That will help us with info on your pool to offer advice as well. :)
nappi.rachelk
6
Utica, NY
OK, thanks for the fast response! I fixed my signature and I'll work on FC correction starting tonight. Do I correct it assuming a CYA level of 22?
The Pool Math calculator says I'll have to add 165 oz of 12.5% liquid chlorine, or only around 1.3 gallons. That feels like a very small amount for our pool! Does it sound right to you folks?
IceShadow
4,189
Milwaukee, WI
CYA will determine your final FC target if you need to SLAM and for daily use, but for right now, you can't assume the CYA is 22. The 3ppm or 5ppm is just to get some FC in the water and prevent you from sliding backward if you do have algae. Once the kit is in, we can do tests to see next steps. :)
