Help With Bearing Replacement
counciloak
2
Granger, IN
Hoping to get some help on finding the right size bearings to go on my Harris 1.5hp pump. It's been getting increasingly louder over the last few weeks. After watching a few videos online, it sounds identical to the motors that need the bearings replaced.
I'd like to have the parts ready before I start dismantling things and I'm curious if any of the gurus here might be able to find the correct set.
Harris Pool Products Pump Model: 156589
Motor Model: CS4M257I1L
The pump manual lists a lot of part numbers but not the bearings (unless I'm blind or stupid)
Also any general advice is appreciated. Thanks in advance!
1poolman1
0
In The Industry
Jul 14, 2014
3,194
Sacramento
Those motors usually take a 6203 bearing. Replace front and rear while you're there.
Reactions: counciloak
