Hi guys (trouble posting from my phone, so moved to my PC)
I just received my Autopilot from @saltpoolguys and I am installing it myself. My question is about the wiring. As I have it now, I have a digital (smart) relay that operates my single speed pump and uses 220V. The Autopilot comes pre-set to operate as well in 220V, so my question is if I should run a new set of wires from the same poles I am feeding the pump off the relay and wire the AP to them. This will , of curse, cut power to the AP central unit and only feed it following my pump's schedule. Is this Ok?...or should I wire it permanently from the circuit breaker.
Another option is to convert it to 110V, make a power cord myself and plug it to an outlet I have available.
Any recommendations?
Thank you!
