Help! Steps aren’t right after gunite!? Can anything be done??
lgibson888
Active member
Apr 4, 2020
43
Texas
Before our gunite was installed Friday, I raised a concern to our PB that I didn’t think there was enough room carved out for our steps. I was assured that this was normal for pools, and the steps would be 12” height with the last step into the pool being slightly bigger.
At that point, the steps weren’t framed, just a slope( see pics) so I couldn’t really invision what he was saying, but trusted him.
Fast forward, gunite is installed... steps are 9” height until the last one into the pool is 18 inches!!!!!! ???? That is my 9 year old daughter....
Can anything be done now that gunite has been installed??? He should have started further back onto the tanning ledge to get another step in. The whole point of the design was to not have the steps protrude into the pool!
Please tell me this can be fixed ??? he has not responded to my message yet.
62AAF026-7F00-4582-9371-2F463BB2B0E2.jpeg4AF2CB95-E49B-462F-B596-C89A3F50C4B8.jpeg99CB1500-CA99-42C0-A7F0-85121C605DBE.jpeg0EFB9D91-0A20-411C-9631-EED963CA8F0B.jpeg
carnivalday
585
Ocala, FL
Did he draw up any plan? I looked up the pool code in Texas and it says, if Im reading it right, that pool steps have to be no higher than 10 inches.
Green25
99
DFW
I think this section of TAC applies to public pools, but I hope your PB is able to remedy. That’s quite a final step.
DB-Cooper
442
Austin, TX
Pentair Intellichlor IC-60
I understand your concern. It probably won't be as bad under water, but I could see them just putting another step in the wall. It will consume some pool volume, but once under water it won't be a real issue. They could re-enforce it into the existing gunite and tie it in.
Excuse the bad Photoshop, but here:
lgibson888
Active member
Apr 4, 2020
43
Texas
That’s what I’m thinking the only good option will be. But I just didn’t want anything protruding into the pool area... ?
He called me back and said he would “figure it out, not to worry “
sorry, that doesn’t make me feel better!
DB-Cooper
442
Austin, TX
Yeah, I felt bad as I wrote that, but as I let more time to by, it was less of an issue for me as it won’t affect your swim lane. You may need to consider step tiling so people see it as it’ll be an obvious obstruction in that walk way, but honestly I don’t think it’s a big deal and definitely better to have than not in this case.
One other option is make the step wider so it’s consistent across the entire pool length. Might be nice for people to step up and hang out at the pool edge and get the ~1ft height boost. It’d cost more but maybe your PB can eat that since he/she messed up.
Also, “we’ll figure it out” is the PB industries stands are retort for, “Oops, I hope they forget about it”.
DB-Cooper
442
Austin, TX
That looks like it would be a trip hazard.
Hence why I said you’d want step markers or consider widening it the length of the pool. Trip hazard or fall hazard?
carnivalday
585
Ocala, FL
Or maybe instead of a step, they can just add a gradual rise (like walking out of the ocean) a foot or two out that would rise up 6 inches or so. That way someone wouldnt break a toe if they accidentally hit a step that was there. Might not look pretty, but once the pool is filled, you'd never notice it.
Rich D
962
MA
Or maybe they break out the jackhammers and the saws and get it right the second time. This is 100% the pool builders problem. It is his job to make sure his subs get the correct measurements and build it correctly. I would imagine he probably was not even on site when the gunite was done. There's no reason those steps could not have been 12" and made it work perfectly. Personally I would not be happy with any of the "fixes" discussed so far.
You also need to consider if any "fix" will hinder the type of pool cleaner you are going to use.
mariane
1,105
Southeast Michigan
^^^^what he said.
I've broken toes on so-called "marked" step hazards. I know I would not be happy with a step protruding into the swim area. I guess you might get used to it but I know I would break another toe. ?
String2005
126
Granbury, Texas
We had the same issues and concerns...they originally had only three steep steps but thankfully we caught it before the gunite was done. My concern was injuries due to missing steps and stubbed toes and my 87-year old MIL lives with us so we did not want to take a risk of her falling (if she ever gets in the pool) due to the steps being too steep. I don't know the process or if it could be done, but it may be better to have them jackhammer that out, add another step and keep it in line with the ledge so there is not a step hanging out there that could cause injury.
lgibson888
Active member
Apr 4, 2020
43
Texas
I stood my ground and they fixed the steps! They look rough now, but I’m assured plaster will fix that. They are all 10.5-11”.
I wish they had just installed another step, but I’m happy with this too!
hopefully plaster next week!
