Help! setting partial open valve postion for pentair actuator valve ? or other troubleshooting for low water flow for solar heat system
bosco
17
arizona
hi!
I have a solar pool water heater system - There is no connected spa, It has a
Sun touch controller with a 3 way actuator valve (Pentair?) which was installed by a local solar company.
The issue is that when the system is set to divert the water to the rooftop solar coils, the pump pressure gets high, and the water flow gets very low (return water jets very low, skimmer basket low) - I called for service, but they cant come for at least 2 weeks! By then in AZ I may not need my solar heat at all!
I remember in the past them mentioning to me that it is possible to set the valve to partial open so that only some (70%?) water is diverted to the roof, before returning to the pool and some goes directly to the pool. This might help to allow for some heating, and still some skimming.
Another thing I was thinking is that something maybe obstructing the water flow through the solar coil system - possibly air?
Any suggestions welcome.
Note this is a vacation rental house, so I dont live there. I am going out soon to look at it, and will upload photos.
bosco
17
arizona
Darn Nobody knows anything about the Pentair actuator valve?? If I could just figure out how to adjust it for partial flow when "on" I think I'd be ok for a couple weeks.
ajw22
29,033
Northern NJ
Pentair Intellichlor IC-60
Oh, that is what you are asking.
You open up the actuator and adjust the cams that hit the microswitches for the stop points.
Reactions: bosco
bosco
17
arizona
Ok, thanks for both links. very helpful "light evening reading" & I will adjust the actuator in a few days when I'm out at the house again.
I'll work on finding troubleshooting resources somewhere on solar rooftop coils. If I figure anything out I will post.
bosco
17
arizona
Post a pic or model number of the actuator valve, and others may be able to assist.
Thanks for suggestion. I was just out at the house and the tenants seem happy with the temp for now. Solar blanket overnight w/o solar rooftop coils has pool at 85 in mid-afternoon. not bad. :) - I wont be there again for a few days & will post a pic when I am.
Rancho Cost-a-Lotta
2,434
Rancho Cucamonga, CA
CircuPool RJ-45
Pentair offers a couple of different actuators. One has adjustable cams inside, and the other, the Intellivalve, can be adjusted externally. Just wanted to confirm the type you have.
Best of luck!
Reactions: bosco
bosco
17
arizona
Best of luck!
yes, I dont think its an itellivalve. I remember a year or two ago a service person came out and adjusted it manually by taking off the valve handle. I dont remember seeing anything like the link you share here.
