Help needed tracking down spa overflow filter basket
DustinATX
17
Austin, TX
We have a spa that overflows via a ~4.25" diameter drain down to the pool. The previous owners had a basket that sat in the drain and prevented leafs from falling into it. That basket started to disintegrate so I replaced it with a basket I found at Leslie's. The new basket seemed to fit fine but after even just a few leafs falls into the basket it gets clogged up and the water starts to rise in the spa to the point that it has almost overflowed a couple of times.
I think the problem is the new basket is straight and the last basket may have been tapered. Also the new basket has much smaller holes. I have tried drilling larger holes into the new basket but that doesn't make a difference.
I need to track down the correct basket for this setup or at least a better basket. Everything else on the pool is Hayward so I'm thinking this could also be a Hayward product.
See the attached photos. Any ideas?
I appreciate it!
Bama Rambler
23,697
You're right about it being a Hayward.
Here's a link to the lid SP-1096 Lid
And here's one for the basket. SP-1096 Basket
Just be aware that you said that it was a 4-1/4" and this basket is 5-1/8" diameter. You might also be able to take the dimensions and find a tapered basket that will fit.
DustinATX
17
Austin, TX
Thanks for the replies. @Jimrahbe I didn't see a link in your post. Do you happen to have that? @kimkats Unfortunately, I don't have the old basket. That would be helpful! The new one seemed to fit so I threw the old one a way. The problem didn't present itself until the leafs started falling. @Bama Rambler I'm thinking the lid may not match the basket because this is definitely a 4-1/4" hole.
kimkats
42,454
Tallahassee, FL
So lets try this...............get out your tape measure it measure the skimmer where the basket goes. Give www.inyopool.com a call with what you have going on. If anyone can fix you up they will be able to. Make sure to tell them TFP sent you for the white glove treatment!
I pinged Jim to let him know the links did not take.
Kim:kim:
