Help needed - Chamber next to skimmer
Spyrus
0
May 21, 2018
10
Indianapolis, IN
I'm not sure what this chamber is but I thought the water level was supposed to always stay low. We got a TON of rain last night and when I looked in this chamber/hole today it was the highest I've ever seen the water.
Should I be worried? Should I try to get a pump down there to get it low again? What is its purpose?
As long as the water in the pool is higher than the water in the tube, you should be ok.
The main concern is when the pool is drained and the ground water is high, the pool can float out of the ground.
Try to make sure that the water in the pool is always at least 18" above the water in the tube.
