HELP! My Intex AGP pool liner needs repair
PoolLoveLady
22
North East
Hi. I am about to patch the liner with Boxer 100 vinyl pool patches. Which side of the vinyl patch does the adhesive go on? One side is slightly smoother then the other. Thanks!
Chad1979
75
Northwest ohio
I had to patch my pool earlier this summer and my vinyl patch didnt say it had to ge a certain way. I just cut the proper sized pieces and patched as the kit told me to. I dont believe there is a certain side to apply the glue to. I double layered my patch as well as it was on bottom near a seam.
PoolLoveLady
22
North East
Thanks! I used a small rectangular peel away patch that came with the pool liner. There is a tiny dripping leak on the outside. Do you think it would be ok to put the larger round patch over the existing one instead of taking it off? Thanks!
Chad1979
75
Northwest ohio
Yes, just make the second patch larger than the first one by a decent amount. Take your time and make sure its applied without air bubbles. My double patch has held up pretty well so far this summer since being done. The water pressure propabaly helped seal it as well as the adhesive cured too.
