We are having a new fence installed around our pool. I thought it would be a good idea to put the solar cover on to help keep debris out. Before I did this, I upped the Chlorine Level and added algaecide.
8 days later, I take off the solar cover and the pool is green on the bottom. So, I turn the pump to filter and vacuum. I had to backwash twice during this process and added water from the hose.
I tested the chemicals and got ready to slam. After adding 3 gallons of liquid chlorine, 1 every hour, it was still at 0. So before I screw anything else up, I stopped and thought it was best to let it filter while I get help.
Taylor Test:
Cl 0
pH 7.2
Alkalinity 170
Calcium Hardness 312
CYA <20
Taylor Test:
Cl 0
pH 7.2
Alkalinity 170
CYA <20
