You should drain no more than 1/3, or if your pool is rectangular with deep end, you can go as far as leaving 1 ft of water in your shallow end. Honestly, I'd go with the 1/3.
You should be out with the pool the entire time you are draining, It might take 30 min, or could take longer, depends on your pump.
