Help: Main Drain body screw hole stripped (Vinyl inground pool)
esurfer
Active member
Jun 28, 2013
34
St. Louis, MO
I'm working on replacing my liner and have the liner off and doing some floor repair. I discovered one of the holes in the main drain body is stripped.
The hayward screw set for the drain is SPX1039Z18
Here are the options I have thought of:
leave that one screw out hoping the new liner will not leak.
Use a slightly larger screw, but I'm wondering if i can find one.
tap a new hole next to the old one in the drain body and the plastic ring.
Shift the whole ring and create 8 new screw holes, fill the old ones in with silicon.
Wrap the screw with a bunch of teflon tape and hope it holds it down well enough.
Fill the stripped hole with some sort of epoxy and drill a new hole.
Attached is the part diagram from Hayward with red arrow pointing to stripped hole.
Any recommendations or opinion on my options?
jimmythegreek
In The Industry
Aug 10, 2017
3,821
Morris Cnty NJ
I just rotate the retainer ring halfway between the holes amd predrill them amd run screws thru with a hand screwdriver so they're ready to go. In your case i would use silicone to ta k down gasket so holes stay lined up when you feel for the holes with liner in place.
