help ID my gas heater
JoyfulNoise
Platinum Supporter
May 23, 2015
17,444
Pentair Intellichlor IC-40
Looks like a Sta-rite Max-E-Therm....are you running natural gas (from a local utility) or propane gas from an on-site tank ?
Reactions: JamesW
JoyfulNoise
Platinum Supporter
May 23, 2015
17,444
If you don’t know the size of the heater (measured in BTU per hour), then you can estimate it by watching your gas meter when it runs. Simply run your heater for an hour and look at the volume dial before and after. Every cubic foot of natural gas is roughly equal to 1000 BTU’s. For example, a 400,000 BTU/hr pool heater will use a little more than 400 cu ft of natural gas (gas heaters are typically 80-85% efficient).
You can then update your signature with your heater’s model and size.
