Help get my pool clean 😖
Sep 5, 2017
13
0
Bear Delaware
#1
How’s it going guys. Got my pool opened green as a swamp from bad pool cover. The guy that opened it advised me to backwash it 2ce a day and add 5 lbs of shock a day until clear. Well after 25 lbs of powdered shock 4 gallons of 12.5 % liquid shock and almost 50 lbs of earth I need to be more efficient.
I have a tf100. The pool is cloudy blue with some algae at the bottom. / I have been vacuuming and scrubbing 1ce a day
cya is 20-30 And fc was testing at 1.2 I figured let me get it up to shock value of 14 and with a 26,000 gallon pool it called for 4 gallons of 6 percent bleach (no name brand, dollar store) I tested 40 mins after and got 7 Nowhere bear shock value. Not sure what I’m doing wrong
many help would be great
Casey
10,516
1
SW PA
#2
With a DE filter, you have the ability to do a record SLAM like I did with a green swamp in less than 48 hours but... You have to get to SLAM level and KEEP IT THERE!!! Get every bit of debris off the pool floor and babysit your DE Filter. Brush the pool walls and floor. Test your water with your TF100 or K2006C 3 times a day at minimum and use liquid chlorine only. You do not need magic potions from the pool store. You can find my SLAM in this forum. It may be on second page by now.
First SLAM in 10+ years
Sep 5, 2017
13
0
Bear Delaware
#3
thats just it. I cannot babysit the filter. I can backwash / make adjustments at 5am and don’t get home from work until 430pm Any reason why my Fc didn’t rise to shock levels with the 4 gallons of bleach ?
Casey
10,516
1
SW PA
#4
As soon as chlorine hits the pool water, it becomes consumable by the algae and sunlight. You've got to keep checking the FC to get it to SLAM levels.
Th e weekend is coming. Are you off? If so, devote your time to the pool, testing, filter cleaning, brushing and vacc'ing. You can make a huge dent in it.
Sep 5, 2017
13
0
Bear Delaware
#5
I am off this weekend. I was hoping to have the pool ready for a party on sat. Oh well there is the whole summer. Anyways. If I throw in a bunch of bleach and it doesn’t raise the levels. How soon can I throw in more without hurting my liner ?
EDIT.
WOKE UP at 430. , backwashed and tested water cya 30. And tested FC. CAME BACK AT 1.2. I added 4 gallons of the same no name bleach and 1 lb of Clorox shock. Tested water again after 20 minutes. FC DID NOT RAISE AT ALL
POOL IS CLOUDY BUT CAN SEE THE BOTTOM. ONLY SLIGHT ALGEA ON SOME OF THE CREASES Is my bleach no good ? Why didn’t it raise 1 ppm?
Casey
10,516
1
SW PA
#7
Do you know what's in the powder shock you're using? What is the name brand of the bleach? Are you sure it's 6% or could it be 3%?
I know my eyes are bad but do I see the liner print on the shallow end of the pool? I think I can! Thats a good sign.
Sep 5, 2017
13
0
Bear Delaware
#10
GUYS/GIRLS. I CANNOT CANNOT GET MY FC TO BUDGE PASSED 3 drops or 1.5ppm. I’ve added 3/4 gallons of liquid chlorine 10% and still no change. At all. My pool looks better and better everyday. But I cannot getnit to shock level even once
Casey
10,516
1
SW PA
#11
Are you using pool math? Is your gallonage correctly inputted into pool math?
Can you add all your pool specs into your signature? It would help us greatly. How many gallons is your pool?
You need to add 366oz 10% to go from 1 to 12ppm FC.
You are not adding enough chlorine to achieve SLAM levels.
Sep 5, 2017
13
0
Bear Delaware
#12
Fc nightmare going to quit soon
My pool looks 90 pervent there. But there is algea in there I’m sure ofnit. Have been vacuuming backwashing and scrubbing. No matter how much liquid chlorine 10% I throw in I cannot get FC above 1.5. I’ve spent over 200 dollars on trying to “shock”. Cya is between 20-30. Please help me. I’m about to call it quits. In the last 5 hours I’ve dumped over 12 gallons of liquid cholrine in 26000 gallon unground vinyl pool
25 minutes after the last 3 gallons. FC IS STILL AT 1.5. But CC IS 12 Cc ha been climbing while FC STAYS THE SAME
Sep 5, 2017
13
0
Bear Delaware
#15
Re: Fc nightmare going to quit soon
Yes rising through day. Is around 12 last I checked
Tf100.
Fc 1.5
cc 11
total alk 110
ph 6.8 (put in 2lbs of ph raise)
cya between 20-30
JamesW
12,647
1
#16
First, try to keep everything in one thread. Opening multiple threads gets confusing.
You probably have ammonia. You're going to keep on the SLAM until it's done.
It's a bad situation but it is what it is.
Very strange test results!!
Moderator comment: Threads merged together to end confusion
Sep 5, 2017
13
0
Bear Delaware
#17
Sorry about that. Finally got it going I just kept dumping and got it into range at 12am last night. When I woke up at 5am. FC WAS AT .5. Dumped 5 gallons in and got fc to over 14. Should this become easier now. And will I be able to stick to whtbthe calculator says in order to get to shock level ?
Casey
10,516
1
SW PA
#19
Gotgrowth, How are you doing with the pool? I know you were very frustrated with it last time you posted. Did you get to SLAM level? I'm very interested to hear an update!
