Help finding Pentair Valve Actuator (longer screws)
blakeusa
In The Industry
Jul 8, 2010
609
Ashford, CT
I need to find some of the longer screws for attaching the actuator to the three way valve body *Pentair valves.
Have plenty of the shorter screws but none of the longer ones...
Have not tried regular sheet metal screws or machine screws.
The screws, set of 4 is being sold for $28 on Amazon and around the same from pool supply stores. My local warehouse has to order them from Pentair and will
take a couple of weeks. Even then they want $11 for a set of 4 screws.
I believe the spec is 1/4 x 14 / 1.5 inches long stainless steel | Thread forming screws for plastic.
JoyfulNoise
Platinum Supporter
May 23, 2015
17,443
Pentair Intellichlor IC-40
Try ACE Hardware. My local ACE carries every nut, screw & bolt imaginable in both English and metric formats. The longer screws are the exact same diameter and thread pitch as the shorter screws.
JoyfulNoise
Platinum Supporter
May 23, 2015
17,443
Worst case scenario - McMaster-Carr is your friend!!
(I still have one if their old print catalogs somewhere...)
