I'm battling chlorine lock (above ground pool approx 14K gallons) with the assistance of a Leslie pool tech. I'm a longtime pool owner and long time Leslie customer.. 2 wks ago I had a good total chlorine reading but no free chlorine. I took the recommended steps to balance the other chemicals first and then SUPER SHOCKING (4x chlorine at one time) to help break the lock. My latest water analysis now shows Free Chlorine = .28, Total Chlorine = .28 and all other chemicals (ph, Alk, Hardness, CYA) all within range. So we thought we had fixed the CL Lock issue.. Also, pool is crystal clear, no visual issues or smells and very low usage (just 2 retirees and a few adult beverages daily).. So the recommended next step was to shock the pool with a normal amount of chlorine (normal for a weekly shock treatment), so last night (9pm ET) I did so. Very much to my surprise, this morning 6amET my test strip did not register any chlorine reading at all (Total or Free) or so low that the test strip could not detect. So before I head back to the Leslie pool store for yet another water analysis I thought I'd try TFP forum first.. I did see in one of your you-tube videos that draining the pool and refilling was found to fix the chlorine lock issue. any thoughts on next steps and if draining is it... how much water should I drain? I'm hoping it's no more that maybe 1/3. THX Wingnut77
