Help! Can you tell me what this is?
Mdragger88
9,225
Hernando, Ms
Hayward Aqua Rite (T-15)
Swgs produce tiny bubbles all the time, while yours seems a little excessive there are several things that can make this more noticeable
This thread covers alot of the possibilities
Reactions: theskydiveguy
mknauss
54,249
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Very common in the spring. When the water warms and chemical balance improves, the bubbles will become less prominent. Essentially, they will get bigger, but fewer.
Mdragger88
9,225
Hernando, Ms
@theskydiveguy ,
We do things a bit different here…
The main staple is doing your own reliable, repeatable testing.
What is TFPC?
& have a Look over the articles in the link Marty posted.
Also, dry acid isn’t recommended when you have a swg so when you run out you should switch to muriatic acid for ph control
Reactions: Jimrahbe
