Help! C° to F°
ShawnaVH
10
MT
How do I change from C° to F°? We were given a 2001 Tiger River Spa Sumatran Model N that is wired for 115v. When we got it all plugged in it shows up as C°. It is an IQ 2020 control box.
Mdragger88
2,970
Hernando, Ms
Intex Krystal Clear
I’m not seeing anything about that but here’s the manual👇
You may want to call customer service listed on pg 46
Reactions: RDspaguy
JamesW
27,682
Possibly a dip switch or jumper on the control board.
On the back of your control box cover there is a schematic.
It shows where all your dip switch or jumper settings are and the function they perform.
Reactions: Mdragger88
JamesW
27,682
If it can be done from the control panel, there should be a °C/°F symbol you can select on the temperature screen.
If not, then it is probably a jumper or dip-switch on the board.
JamesW
27,682
Was the old power supply the same voltage as what you are using?
Go through the installation manual and wiring instructions to verify everything.
If you are unsure about anything, call a service technician to make sure that it is done correctly and to make sure that it is safe.
ShawnaVH
10
MT
Here is the pictures of the circuit boards
ShawnaVH
10
MT
It looks like the smaller board has been replaced.
JamesW
27,682
The red HTR (Heater ON) LED indicates a call for heat.
Are you sure that the circ pump is not on?
How do you know that the heater is not heating?
JamesW
27,682
Did the old owners say that everything was working?
Is the voltage the same now as it was for the old owners?
I don't know the correct wiring for this model so I can't confirm that it is correct.
Are you sure that all of the wiring is correct?
How did you know what the wiring should be?
