I bought an above ground pool (18' x 52" round) in May 2020. For various reasons I did not get to use it and winterized the pool in October 2020. I recently opened it up for Spring 2021. The pool has dual main drains and a skimmer, steel walls, unibead vinyl liner, Pentair pump and sand filter system. I believe the pump is 1.5 hp. It has a Power Ionizer system. I look forward to learning more about the daily operations. I have had other above ground pools that were not permanent. Thank you for being here.
