Heating Modes
cledee
166
Concord, NH
I have a Hayward Universal heater, currently hooked up to natural gas. I only have a pool, so my question is could I use spa mode to heat the pool to 104? I wanted to heat up the pool one day to hot tub levels in October a couple of weeks before closing the pool.
mknauss
44,835
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Must have a max temp set for pool. That can be changed if you want. Or, if you can, use spa mode to warm it up.
Reactions: cledee
cledee
166
Concord, NH
I bet when it was installed it was preset to 90 degrees. I was able to look up the manual and find out how I could reset and set a new max temperature. It involves placing it on standby mode, holding the up and down buttons which brings you to the temperature max setting. Then you can press up or down to set the new max. I will try it later on today when I get home. If this doesn't work, I'll just put it on spa mode.
Reactions: mknauss
Weasel2017
63
Canada
Jandy Aquapure 1400
I have the 250k Universal and it was preset to 90 from factory. What you have listed is how I changed mine to a different temp - actually lower than 90 to keep the kids from turning it up ;-)
Reactions: cledee
cledee
166
Concord, NH
Yeah, I just tried it and it works. Got the max set to 104. Once we get to October I will set it to 104, for one last weekend of fun, before closing it for the season.
Reactions: Weasel2017
