Heater won't heat higher than 95 degrees
DougS
32
Pleasanton, CA
Hi all,
My heater "works" but the SPA gets to about 95 and then won't go higher. The temp setting is at 104. It seems to light, but then quickly turn off after it gets to 95. It tries again, but then stops again.
It's a Pentair 250N, purchased in 2012.
ps0303
In The Industry
Jul 6, 2011
3,968
FL
When you say 95, is that what the ET says or the heater display?
Esloser
513
Millville, NJ
Check which setting your heater is in. I know I read something in my Hayward Heater manual about the pool having a max set temperature and the spa's being higher at 104. I can't seem to find it right now.
CountryBumkin
124
Orlando/FL
On my RayPak heater the instructions say for remote control use set the heater's internal setting to max (104) before switching over to remote operation. So if you missed this step, and say only set the internal heater setting to 90, even if the remote is commanded to heat to 104, the heater would shut off at 90.
Perhaps this is your problem.
DougS
32
Pleasanton, CA
Thanks. Mine is a Pentair, but I think there is a similar setting. However, I doubt that is the issue because it just started happening. Still, I'll see if I can check it. Thanks.
ps0303
In The Industry
Jul 6, 2011
3,968
FL
I would say to eliminate the ET system and use the heater controls only to see if the heater gets past 95. If not, then you have an issue with the heater. Also make sure the heater is set to 104.
Thread starter Other Threads of Interest Forum Replies Date
R Everything Else 1
O Everything Else 3
K Pumps, Filters, and Plumbing 1
