Heater problem
michael60
8
New York
We have an in-ground pool with a Max E Therm 400 heater. Last year the heater wasn't working.It turned out we needed a new control board which was replaced at a cost of $975. This year we needed a new pump and had the same company back to do the work but when three weeks went by and after multiple phone calls we had a green pool but no pump I fired them and called another company which installed the pump 2 days later. 2 weeks ago I tried to turn on the heater and noticed the screen was blank. I popped off the top and discovered someone had stolen the control board that was installed last year. Now we have no heater. The two companies that worked in the yard claim to know nothing about this. Since it seems to be very plug and play and I am reluctant to let either company back in the yard or pay another $975 I bought a replacement control board online and installed it myself. The problem is that its not working. I contacted pentair and they can't figure out what's wrong. When I turn on the power I get a series of codes 888 then 128 then r14. I don't know where to go from here.Do those codes mean anything to anyone? Thanks
MyAZPool
1,816
Arizona
Pentair Intellichlor IC-60
michael60
I'm really sorry to hear about those bad luck incidents regarding your heater. I'm feeling for you there.
I certainly can't be of any assistance to you but there is someone who has provided detailed assistance to others in the past with reference to your heater make/model.
Calling @JamesW
He very well might be of assistance to you regarding those codes.
Good luck with your heater.
r.
ajw22
23,724
Northern NJ
Welcome to TFP.
Those are the normal codes at startup. r14 is the revision code of the board. What happens after all of that?
@ps0303 @Pool Clown thoughts?
ajw22
23,724
Northern NJ
You have any automation controlling the heater?
michael60
8
New York
Maybe this is a crazy idea but if the person who stole the control board also stole another component (sensor or something else? ) would that explain what's happening?
danpik
1,752
western NY
Check and see if this board has a jumper on it that may need to be moved to a certain position to enable the board to communicate with the membrane pad or with outside control (automation)
ajw22
23,724
Northern NJ
Yeah, I was going to suggest you check the wiring. They could have ripped wires or a connector in their haste.
It does sound like you have a keypad problem.
Geebot
933
A little late to chime in but when we purchased our house several years ago we also purchased a home warranty which included the (aging) pool equipment. It's more than paid for itself since we've purchased it. We pay no more than $100 for a repair.
michael60
8
New York
Thanks. I examined the wires and aside from some dirt they appear intact. I would have to take off the housing to follow them all to their origin so maybe ill do that. There is a jumper and I’ve trued it on both positions but it didnt seem to change anything
michael60
8
New York
Its funny you mention that. The pad always had an LED display and this year I noticed its an LCD. I wasn’t sure if that was changed out when they replaced the control board last year but I didn’t remember that being done. Now im wondering if they stole the membrane pad too and then replaced it with a defective one that they had on hand so we wouldn’t notice the theft right away.
JamesW
23,289
The display comes from the control board, not the membrane pad.
Check to make sure that the ribbon cable from the membrane pad to the control board is connected properly.
Check the fireman's switch to make sure that it's not open.
michael60
8
New York
I think I found the problem. The ribbon that connects the membrane pad to the control board is torn on the end near the pad and three of the wires in the ribbon are broken. They must have done this in their rush to remove the board when they stole it. I am ordering a new pad. Hopefully that will solve the issue.. Thanks for all the input
MyAZPool
1,816
Arizona
michael60
Excellent. I'm hoping that does the trick for you when you get the new ribbon connector installed.
Please let us know if that solves your issue. It would be nice to put a final "happy face" on what has been an otherwise nightmare for you I'm sure.
Good luck with that sir.
r.
mguzzy
I would pull up the breakout diagram of the heater from Starite and compare it with your heater to make sure all the other parts are in there as they should be. If they harvested your system for parts there are a few other things that are easy to get to.
BTW.. that just sux!
