Heater just went.. need recommendations for new
ABC12
54
Florida
Been a while since on this site.
15,500 gal salt water pool. The heater that we had when bought the house just went.
Would love a few recommendations for good pool heaters. Just starting my research, so I’d really appreciate any advice on what to look for in a new heater, good features to have, new tech etc.
Thank you all!
Separately- is now the time to make any other changes to my equipment or if things are running smoothly just keep as is? Ultimately will probably need a new SWG soon, and would like to make my system “smarter” - ie controlled from phone/web
(Had a signature way back when, hopefully it posts automatically, if not let me know what other info you need).
ABC12
54
Florida
Found my old signature (got a new pump about a year ago, but the rest should be correct).
POOL NOOB: Size: 15,500 Gal, Type: Plaster/Concrete IG pool, Filter: Hayward Star Cleaner - Cartridge Filter, Pump: Hayward Max-Flo, Heat Pump: AquaCal Heatwave Superquiet, SWG: Pool Pilot Digital by Autopilot, Test Kit: Taylor K-2006 FAS/DPD Chlorine
mknauss
44,344
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Your signature shows a Heat Pump -- best to define what you are looking for. Heater typically implies a gas/propane pool heater.
ABC12
54
Florida
Sorry. What’s the difference? I have the Aquacal… pretty sure it’s a heat pump. Turn it on 24hrs before use and it heats the pool to the desired temp.
mknauss
44,344
Laughlin, NV
Fiberglass
A heat pump uses electricity to pull heat out of the air and transfer it to the water. A Heater uses (in most cases) natural gas or propane to burn and transfers heat to the water.
I believe you have a Heat Pump.
