I am trying to improve the water temperature in my pool. The pool is a 22 000 gallon inground indoor pool and the water is always cold. Middle of summer the water may not reach 70 deg f.(Live in Ontario Canada)
This pool is not used in the winter as the current heating/de humidifcaiton system for the room does not work(Dectron). The previous owner never had it working either. I am only interested in heating the pool in the summer months.
The current heating system for the pool and the house is having the pool water piped into and oil boiler (164k btu) and then piped in series into indoor wood boiler(BTU unknown however would be less than oil boiler). Both of these boilers are probably from the late 60s or early 70s and I will be looking to replace the oil boiler with likely propane as my oil tanks are expired. The wood boiler has the pool pipe reduced down to 3/4" so I feel this reduces the flow too much. These do not do a sufficient job for heating the pool and is making the pool useless as its too cold.
I would like to add a new heat exhanger and size the new boiler to heat the pool. Several websites have different methods for sizing heat exchangers/boilers( So far I have calculated 185 000 - 367 000 btu).
Does anyone have experience that they could share?
