Hazy/cloudy water only after running robot (M600)?
CPM10V
23
Phoenix, AZ
I recently purchased an M600 robot, it has worked real well as far as cleaning (the iOS app needs work). I’ve noticed that after (& during) the water develops a little haze/slightly cloudy; prior to running robot water is much more clear. Any ideas on why the cloudiness? It’s a 25k gal plaster (now painted, previous owner) pool in ground, sand filter. I backwashed filter upon first noticing & water cleared back up, ran cleaner again & cloudy again. Any ideas on whether this is normal or something else going on?
Tenab
162
NE Texas
If you brush the bottom before you run it does it cloud any? If so, you have silt/sediment it's stirring up.
Which filters are you running it with, the screen/fabric (spring) or the corrugated (ultra fine) ones?
CPM10V
23
Phoenix, AZ
I’ve run the unit 3x so far, factory-loaded mesh/corrugated filter set. Think it’s worth swapping out filters to the other set they included? Prior to the first run I gave the pool a cursory brushing, nothing too extreme. I’ll have to brush first & try again/take more notes. Just seems strange/coincidental noticing this after using the robot.
CPM10V
23
Phoenix, AZ
Ah I’ve still got the 2 pleated in & the 2 plastic/mesh (spring) filters in. I’ll
swap out with the other set of pleated filters they included. Maybe that since the “rough” cleaning is done the full fine filtration may capture some of the fine debris that is creating the haze? I’ll post back tonight after trying.
Reactions: Tenab
