Hayward widemouth overflow hole or other overflow techniques?
theskyisthelimit99
394
Pittsburgh, pa
I have the 18' intex pool, now with the hayward widemouth..
I added a 1/2" hole about 3/4" above the pool full line.. and ran some small pvc down to the ground.. one day it rained quite a bit, up maybe 1" in the pool.. the pipe was indeed draining, but it took 8 hours just to go down a half inch.
I kept the hole small because when the kids are in with the splashing i didnt want the water rushing out.
Is there some other trick to this, or is this about as good as it gets given the circumstances?
Thanks in advance
theskyisthelimit99
394
Pittsburgh, pa
Nope, there's no trick.
With a 1/2 inch pipe, its gonna take a while to drain down.
Thanks, Thats what i figured.. was hoping there was a magic solution.. i guess i could go slightly bigger, may 3/4 instead and see how that goes, worst case glue part of the hole in if its too much/drains too fast when people are in moving the water.
chayne
mine has taken that long also. i really didnt want a much bigger hole that is why i went with the 1/2" pipe. i guess you could always turn on your pump and go to waste to get rid of water faster. that is usually what i do once i know there is no more rain coming for a little bit.
Newdude
6,844
NY
What about a 1 inch hole setup with a shut off valve on the pipe ? You could shut the valve when the kids were swimming/splashing and let ‘er rip for big storms.
Reactions: hitech_hillbilly
