Hayward touch screen not working
Welcome to TFP.
You check your circuit breakers powering the OmniLogic panel?
You say it "powered down". What did you do to reset it?
Sorry. I just saw your response. We had several chlorinator alarms going off on my Heyward app. I powered down the wall box from the app then turned the breaker off. I found a 4amp fuse that was blown. I knew the touch screen didn’t work and I saw where it had to be powered back up by the touch screen. For some reason the app will not power it back up. I asked the question about getting around the touch screen before I went to the store to get a replacement fuse. I was worried that I would replace the fuse and not be able to turn everything back on. Turns out when I flipped the breaker everything powered back up and the fuse replacement fixed the chlorinator problem.
