I have a DE Hayward Model EC40C90 Series, Pump model SP1580/TLFP, 1.0 Horsepower, Perflex filter model. It is for a 21" Round above ground pool. I've had this issue since it was new. I just opened the pool and the water was green. I turned on the pump, added proper chlorine and baking soda. The pump worked fine for a few hours then it gears down and has very low pressure. I back washed all the green stuff out, but it will still only run hard for a few minutes. I initially thought I had put too much DE in, but I used exactly what the book said. I backed off on the DE a little bit last year and I seemed to run fine. Any suggestions?
