Hayward PoolVac XL Problem with Leaf Canister.
AZTom
3
Phoenix, AZ
I’ve been using a Hayward PoolVac XL with a Hayward Leaf Canister for years. Just purchased a new PoolVac XL and installed with new hoses. It is connected to a suction port not the skimmer. Now the hose gets hung up on the leaf canister when it passes underneath and will not move from a small area. Never had this problem before. Same suction and speed is set on the new PoolVac as before. Any ideas?
Are leaves your pool's nemisis or do they just cause problems in the fall?
Have you ever considered a robot? I ask because I see a new Hayward PoolVac XL is about half the cost of a good robot which also provides more features such as brushing your walls, and *not* needing a pump to run. Just plug 'em in to a power outlet.
Any chance you can return the new PoolVal XL?
Maddie :flowers:
