Hayward local display just keeps resetting??
Sphife904
1
St Augustine, FL
Have a Hayward Aqua Logic system, and my local display (PS8) just keeps power cycling when I flip the breaker on. All lights along with display screenwill flash on and off a couple times while beeping, then lights stop but beeping continues. I’ve checked the 20a & 3a fuses and they’re good. The system will still run from 10-5 daily even with the resetting happening bc that’s what was set previously. I can’t get any voltage from the black and red wires either. Looks like something might of burnt beside the red wire on the board. Any help is appreciated!
ajw22
29,661
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
Hayward boards are known to burn components and solder points. You need to pull the board and examine it carefully.
B&L Enterprises will repair Hayward boards if you are not comfortable doing board level repairs.
@JamesW
Reactions: Sphife904
