What size is your pool?
Is gas an option?
Do you want to heat all the time, or just heat the pool up when you need it?
Is this for a spa, pool/spa combo?
Is gas an option?
Propane is expensive and pricing is volatile. Natural gas heaters are cheapest to run and comes in the largest sizes, heat pump second but only has smaller sizes, propane is most expensive but comes in same sizes as NG. If your climate is mild (Fl), a heatpump should work for you.
