Hayward Heat Pump not reaching set temperature
Danor71
5
Canada
My pool normally is set at a comfortable 28. This morning, I noticed the reading at 24 while it was set for 28. I did a backwash, checked the water flow,, pressure,etc. All is okay. The heat pump is working, the fan is spinning all normal.
I even pumped it up to 30 but it’s still not reaching the desired temp. The outside temperature was 29 today.
Is this a Freon problem?
Thanks
ajw22
28,590
Northern NJ
Pentair Intellichlor IC-60
Could be.
Or the compressor may not be running although the fan is running. The compressor can fail due to a failed capacitor in its motor.
You probably need a service call to diagnose the problem.
Reactions: Danor71
