Hi all, yesterday I fired up the heater for the first time since moving into the house. I heard some knocking and immediately shut off the heater thinking it was boiling water inside with low water-flow. I opened up the manifold and found a broken flow controller, missing controller rod, old flow control thermostat, etc.
I can easily fix these all with some parts, etc. But one of the Hi-Limit switches didn't have a wire harness or anything going towards it. Nothing in serial with the thermostat or shut-off. My question to the group is that there are two (i'm assuming one at 135 degrees and another at 160 degrees) switches but only one harness. Is this because i don't have a spa and only a pool and thus only need the one Hi-Limit switch?
Also - having a heck of a time re-attaching the inlet/outlet back onto the manifold? Any tips?!? Thanks.
