Morning all,
New the forums but in need of some assistance.
I have the above-mentioned board, Hayward GLX-PCB-MAIN (PN: g1-066008n-1) and the 3A fuse is blown.
I purchased another 3A fuse, made sure power was off at house breaker, replaced the fuse and turned on the power.
Immediately blew the 3A fuse again.
Everything I find online talks about the 20A fuse as if there are no other fuses. The 20A fuse is fine.
This is a replacement board that has been running flawlessly for two years.
Inspecting the original board I found the same 3A fuse blown.
I am no electrician, but instantly blowing fuses implies a short circuit but I do not see any.
Nor do I see any burn marks.
Has anyone run into problems with the 3A fuse found under the control panel?
If so, what should I check to correct the problem?
Thank you in advance.
