Hayward DE filter gauge backward
SLUBOPOOL
19
Los Angeles
Hayward Turbo Cell (T-CELL-5)
Hi, recently had my pools remodeled and haven’t had to open or clean my DE filter yet but noticed our Hayward DE4820 48 SQFT DE filter was installed by our PB with the pressure gauge facing the wall. I am making sure after we remove the Upper Filter Body that we can reorient Upper Filter Body 180 degrees so that the pressure gauge faces front opposite the wall when we put it back on? Thanks for the quick help.
I don't think the top is keyed and you should be able to reassemble it with the gauge facing outward.
You see things installed like that and wonder if the workmen know anything about what they are installing.
Reactions: SLUBOPOOL
Thank you. Yes, it’s alarming considering what PBs charge in my area.
That looks like my De4820 filter only a different color. Can't you just loosen the band clamp and spin the top around? You should only need a 3/4 socket and wrench.
