Hayward cs200e filter cartridge
Meaty
59
Dallas Texas
Hi
i noticed a strange sound coming from my filter so I opened it up and noticed the plastic/rubber material at the top is torn. Where can I find a replacement? I checked pleatco but wasn't able to find anything that matched
thanks
setsailsoon
4,281
Palm City/FL
CircuPool RJ-30 Plus
Meaty,
What's the model number on your filter?
Chris
chiefwej
3,735
Tucson
First, I can't find anything on Hayward Pools or any other web sites that lists a filter with that particular model number. Is that the number of the filter or cartridge refill?
Second, the loose plastic/rubber piece you refer to, is it the top of the filter cartridge you mean. Is it torn away from the cartridge? If that's it you just replace the cartridge.
Meaty
59
Dallas Texas
right, on top of the cartridge. The number printed on it is cs200e
setsailsoon
4,281
Palm City/FL
Marty,
Sounds like you are describing the number on a replacement cartridge for a Jandy CS 200 filter. You can check the dimensions on the filter and find a cs 200 replacement. I bet it's identical and will work fine. So I'm assuming there are no other identifying numbers on the outside of the housing. It should have a Hayward label somewhere. Can you add a photo?
Thanks.
Chris
JamesW
28,251
A little research indicates that you might have a Hayward SwimClear Single Element C200S, which takes element number CX200XRE.
setsailsoon
4,281
Palm City/FL
That makes sense. Maybe the number is hard to read on the old cartridge?
setsailsoon
4,281
Palm City/FL
Meaty,
Go to this link on the Hayward site and see if this looks like your filter. If so James just solved your problem.
I hope this helps.
Chris
