Hayward ColorLogic LED Light Not Turning On
joesc230
172
Central, NJ
Pentair Intellichlor IC-60
Hi all,
I have a Hayward ColorLogic 12v LED light in my pool that has stopped turning on. It was blinking a few days ago and now it just won't turn on. I have two other lights (originating from the same circuit) and they are working fine.
I checked the GFCI and the circuit, and neither are the issue. I'm pretty sure the next step is the check the junction box that the light is connected to, but what do I need to do? Connect a multimeter to the two wires coming from that light? (to verify that the light is the issue)
I do see some condensation inside the broken light. It's about 6 years old...from what I'm seeing online (complaints from those that have the same lights), that's not bad a lifespan for one of these.
If the light has gone bad, does Hayward offer replacement parts for fix this? (i.e. new bulb and gasket) Or would I have to purchase an entire new light? I tried searching on their site but it seems that my light was discontinued and the replacement parts listed are not internal parts.
ajw22
29,910
Northern NJ
I think you will find the light is dead and not repairable. You should plan on replacing the light.
joesc230
172
Central, NJ
Yeah, I have that feeling too...it's just a bummer because we barely use the lights...we probably use them like twice a year...my wife wants me to just leave it be and not replace it since the other lights are working and it's like $1,000 for a new light...I'm sure I'll end up buying it though. I'm too anal to not having it working, but that's a whole other story...haha.
BuckeyeChris
824
Buckeye AZ
My hayward light just went. Again. First light lasted from 2014-2017, and then the free replacement 2017-2021. This one easily has under 100 hours on it of actual run time. Iit turns on to full white for a bit, then switches to the color. After a minute it drops out, with only a faint glow in the bulb.
Is there a non-Hayward replacement that can still cycle through colors by cycling the power (like the current one does, we don't have the colorlogic app/controller)?
BuckeyeChris
824
Buckeye AZ
I see some OmniLogig software updates say this. i've never updated the soft/firmware of my controller though...
  • Pentair and Jandy light control: Control the colors and shows of Pentair and Jandy Color LED lights from the Controller or Hayward OmniLogic App version 4.2.5. Not supported on legacy OmniLogic iPad app.
