Hayward Aqua Rite
Philo
922
San Diego, Ca.
My neighbor has a Hayward Aqua Rite T-15 that I try and help him with. It is displaying the salt level at 4500ppm on instant and average. The Taylor test kit shows 3600ppm. It is not flashing "high salt". All the other diagnostic readings are good. I usually see the display reading lower than the Taylor test when it is about to die, not higher. The cell is newish.
Is that common?
mguzzy
2,176
OV, CA
Check and make sure the controller is set to a T-15 and not some other cell type. I have seen the salt reading mis reported if the cell type is incorrect.
Philo
922
San Diego, Ca.
Thanks!
(I noticed it's really a Hayward Swim Pure...)
The cell is 2 weeks old.
The readings today are:
4500
84
24.1
7.27
100p
-4400
AL-0 (when I scroll here it goes AL0, AL1, AL2, AL3, AL4, AL5)
r1.4
Taylor 3600ppm
Any other ideas? It's kinda of bugging us.
JamesW
20,289
The Hayward cells are made with high quality. Cheaper cells are not made as exactly as the Hayward. Most likely, the cell is over-performing and causing the salinity to read higher than actual.
I wouldn't worry about it. Just go by the readout on the box.
Don't let the amps get to 8.0 because that's where the high salt warning trips.
Periodically, check the actual salinity against the readout to see if it's the same performance percentage.
If the cell begins to fail, you will see the performance percentage drop.
The performance of the cell can be calculated by dividing the instant salinity by the actual salinity. 4,400 ÷3,600 = 122%
As long as the readout ÷ the actual salinity is above 75%, the cell is fine.
JamesW
20,289
The higher the amps, the higher the chlorine production.
The production percentage is based on the expected performance of a new cell.
The performance will increase with higher salinity or higher water temperature.
Philo
922
San Diego, Ca.
It's a neighbor's. It looks pretty cheap. I don't see it on Amazon or ebay. When I see him again I'll ask.
I'm curious about your new one. I hate the OEM $550.00, they fail early also.
wireform
In The Industry
Aug 15, 2017
1,473
Spring Valley, NY
I sort of disagree with your statement. This customers cell is 9 years old as per serial number and pool was closed for two seasons which gave it a six to seven year life. At that point the cell owes him nothing. Cell longevity is usually dependent on proper sizing, proper install, very good chemical balance as per TFP recommendations and proper care. Not to say there isn't a bad apple in the bunch but the people that get good life out of the cell are the ones that don't let anything slide by. By the way "cheap is expensive".
