Hayward Aqua-Plus GLX-CELL-5 Not Creating Chlorine
mpride
81
Sugar Land Texas
Recently my SWCG stopped producing chlorine. It’s less than a year old so I thought maybe it was dirty so I cleaned it although it looked very clean. I put it back in the system and it still didn't work. I then decided to clean it with an mild acid wash. Still no change. At that point I decided it must be bad so I purchased another one. Guess what? Same issue. Soooooo, I then thought maybe I would reset the system by cutting power to the system for a few minutes and then powering back on. Still no change.
What would be my next step with this? Is my control panel having issues?
Current salt reading: 3360ppm
Errors: ‘Chlorinator off Test Salt Cell', 'Check System Very Low Salt'
JamesW
16,791
Go to diagnostics and see what the readings are then change polarity and see what the new readings are.
JamesW
16,791
Reverse polarity and see if the readings change.
If not, unplug the cell to see if the plug is burned.
mpride
81
Sugar Land Texas
The plug isn't burned on either of the 2 SWCG's. I'm not sure how to reverse the polarity. I believe you press the + or - button when in the Chlorinator Diagnostic menu correct? I can't actually view anything but an error when I try to look at that menu. Is there anyway to get around this?
mpride
81
Sugar Land Texas
Go to configuration and see if the cell type is set to T-5.
You have 2 salt systems?
I just have one salt system. I purchased a second cell because I thought the first one was bad. I just checked the configuration and it is correct. I wish that had been it.
JamesW
16,791
Have you done an independent salt test?
Turn the percentage to zero and make sure that superchlorinate is off. Wait 1 minute and then turn on superchlorinate and recheck the readings.
mpride
81
Sugar Land Texas
After doing that it looks like the Chlorinator is working. I was able to get to the Chlorinator Diagnostics and Instant Salt menus. Its showing 0000 PPM Salt at the moment. I was able to changed polarity so I did that. I guess Ill let it run to see if it begins to register any salt. I hope it works.
Thanks for the help. I appreciate it.
JamesW
16,791
I suspect that it's probably a problem with the power supply. It should be under warranty. You should not have bought a new cell because you have a 3 year warranty on everything. File a warranty claim with your builder and let them figure it out.
mpride
81
Sugar Land Texas
My pool is probably 11 or 12 years old at this point. No warranty except for maybe the 2nd SWCG I just purchased.
JamesW
16,791
In your first post, you said that the SWG was less than a year old?
Try turning it off and then back on and recheck diagnostic readings. Reverse polarity and recheck the readings.
Note amps, volts and salinity in both polarities.
