hayward aqua plus: check system light on
JamesW
19,249
CSM stands for (Chemistry Sensing Module), this error appears when Sense & Dispense is enabled, but the Chemistry Sensing Module is not found.
Do you have Sense and Dispense?
If yes, verify that it's plugged in.
Uncle Salty
291
South Carolina
It’s a separate system for PH and ORP monitoring and a total waste of money. I’m guessing that you don’t have it and have it enabled which is why the error. Should be able to disable it in the configuration menu I believe.
Salty
Feneche
56
Las Vegas
Are you new to the pool?
Do you have a picture of the system?
How old is the equipment?
Tnx for the ****
Yes,I'm kinda new to all the pool maintenance thing
I got the this model
The equipment is new no more than a year old
I will look if there is any enable... and see if I can disable it if I will find it
Feneche
56
Las Vegas
You guys are amazing
I watch the video clip and think I find the problem
I didnt fix it yet but I remmber that I sow the chemistry wizard on the manue It could be that I touch it by mistake
I will try it when I get back home
Reactions: Uncle Salty
