So I installed the AQR15 and it says it's working correctly. I have about 16k gallons. I added (for a new startup) 10 bags of salt. It's been running for about two weeks. I've never had salt before so I followed the directions for adding salt.
The Hayward manual states to add 427 pounds of salt for 16k gallon pool. I went ahead and added 10 bags, 40 pounds each. My salt PPM is 3400. So I know I'm good.. (at least I think)
So the AQR15 is rated to handle a 40k gallon pool. My pool is only about 16k gallons. So I first put the SWG on 40%. It didn't seem to be working well. So this past Sunday, I tested the water and I used my Taylor test kit and I got a reading of .2 of chlorine. Which seemed to be a bit low. My pool was not clear either. I changed the SWG to 60%. I think that should be fine.. (my math is, 40k gallons / 2 would be 20k gallons. I'm only at 16k gallons so 40% should be fine.) however, I'm at 60% and the test still isn't 100%!
So, with this, I put my SWG on "super chlorinate" and added 4 bags of shock and 2 chlorine tablets. My pool the next day was (and still is) crystal clear!
So that was sunday and today is Wednesday, so I tested my water tonight for chlorine and I got a reading of .2. (only took one drop to turn my test water clear.)
So my question is, should I be getting the same chlorine reading with my test kit as I would if I was using normal chlorine chemicals? This just doesn't make any sense to me what I'm getting. I'm wondering if the SWG is actually workin properly.
Any help would be greatly appreciated!
I can take a video of everything if needed.
Thanks!
Chris
Thanks!
Chris
