Opened pool up on Tuesday-had some help, first time. The water was beautiful-the pool guys were impressed. Ran the robot all week cleaning a bit of sand off the bottom. They dumped a gallon of thier shock before i could say anything. Been running the pump at 2350 . Finnaly did a water test today. Water temp 58°.
FC 8 with FAS-DPD test , can this be right? ran it twice. 3 hours apart with different samples.
CH 250 (vinyl pool no issue)
TA 70 (vinyl pool no issue)
CYA 40 (need to add 5 Lbs)
Salt 3000 (need to add add 95 Lbs)
Ph 7.8 (keep monitioring, a bit high)
Looking for some input on the high FC............
