Thanks, more info. for you:garrybunk said:Looks great! And looks pretty easy to do. So your valves at the skimmer & return will stay in place through the winter? Is the Hayward Union missing in these photos? Or where is it? I'm confused what is special about the Hayward Union.
Do you think all the 90º elbows will restrict the flow any? Or would the difference be negligible? I've read of others using 45º's instead for that purpose, but I'm not sure how you'd even do that in your setup. Guess you won't really be able to test for flow & pressure 'til Spring.
Garry
1) My valves in the skimmer and return will NOT stay in place this year because I already tore down the original setup. No sense leaving them in this winter. As far as next winter, I will decide then. It depends on how I feel about the wear and tear of threading them with teflon tape and removing them each season vs. possible freeze problems with valves in place. Others here have said the valves in place are not a problem.
2) Hayward Union - Look closely at the pump, that union is black in color. I glued it to a short piece of 1 1/2" pipe to the first elbow. You can't see it because it doesn't need the "other half" of the union because the pump is that "other half". So, LOL, I guess you could call it a half union. That was an added cost but I hate those jumbo unions (see at the filter head).
3) I don't think 90 degree elbow would restrict flow too much, but I'm also not a plumber. I was running about 20 psi (on my gauge, all gauges are different) on my flex hose setup. If there is a significant increase I will certainly reconsider. Maybe one of the peeps here could let us know what a maximum resistance would be on a setup. I'll have to dig up my pump manual.
