Hard Piping Sand Filter
pmsmith2032
163
Northern Illinois
My filter has developed a leak between the Hayward pump and the Hayward sand filter. I have tried cutting off the end of the hose (1.5" braided clear hose I believe), tried using multiple clamps, magic lube, plumbers tape, etc and it is still leaking. What is the best way to hard plump this? Do I just use regular PVC pipe? I imagine I need some kind of connection so I can remove the pump when I winterize? What kind of connections. I will hard pipe from pool to pump and from filter to pool in the spring. Below is a link to the filter I have (SW256).
https://www.shopthegreatescape.com/clients/20/assets/14/Swim%20Pro%20SW196T-236T-SW256T%20ISSW256T.pdf
Thanks!
pmsmith2032
163
Northern Illinois
I'm at work right now so don't have an actual picture but if you look at the first page of the link I posted, it is the run from the pump to the filter (there is a hose in the picture).
partsman
236
Westerly RI
No problem...after looking at the replacement parts in the manual you posted, the fittings are inch and a half.
From your local Home Depot, Lowe’s, etc...you will need...
2) 1 1/2” threaded male adapters (one for the valve, one for the pump)...these are threaded on one end and have a 1 1/2” solvent connection on the other end.
1 1/2” elbows...I would say probably 2.
a couple short lengths of 1 1/2” pvc pipe
1 1/2” union with solvent ends on both sides
pvc primer and cement
Make sure the connection at the valve doesn’t restrict usage, removal, etc...this also applies to placement of the union.
Good luck!
partsman
236
Westerly RI
You might be able to do it with one, depending on where the valve inlet is in relation to the pump outlet. I was just going by illustrations in the link you posted.
