Hairline cracks in my Heyward 180 T sand filter tank
RhondaF
Active member
Oct 17, 2014
27
Conyers, GA
Intex Krystal Clear
I have a 27' ( I think) round above ground pool I guess its gonna be another one of those expensive seasons:/ I have a few problems. I have 2 hairline cracks in my sand filter tank. I tried to patch it with flex seal pool patch tape but it didn't help much (now its dribbling instead of spraying). The other crack is at least as big (1/2") but isnt leaking. I cant find a tank for sale without the valve etc. Can I fix it? Its old... I don't remember ever replacing the tank (only the valve and lateral thingeys) and I've been here 15 years.
Also, my Intex salt water generator has died, again. Theyve gone from $150 to over $600 this year and I just read about a chlorine shortage...aaaarrrggghh. Any advice ? We tried to bypass something (low salt light) but it didnt work. I've got leaks at most of my connections but I don't want to give up on this pool. Help!
RhondaF
Active member
Oct 17, 2014
27
Conyers, GA
Intex Krystal Clear
I should add that the 2nd crack must have just happened and it's at the exact same level as the one that's leaking water. Maybe I need to redistribute the sand??
RhondaF
Active member
Oct 17, 2014
27
Conyers, GA
Intex Krystal Clear
No. It has to be replaced. Filters can explode and cause serious injury.
Oh Crud. I just put all my "close the swamp" chemicals in there :/ Do you know if I can replace just the tank? Is it safe if i turn the pump off?
zea3
13,808
Houston, Texas
The filter body is a pressurized vessel. Once it develops cracks in the body it is not safe and it is not repairable. What brand and size sand filter do you have?
Reactions: RhondaF
RhondaF
Active member
Oct 17, 2014
27
Conyers, GA
Intex Krystal Clear
Hayward S-180T ..holds 150 lbs of sand. I just turned the pump off, do I need to drain the filter?
RhondaF
Active member
Oct 17, 2014
27
Conyers, GA
Intex Krystal Clear
Thank you guys...just did a tiny bit of research and am embarrassed for asking the question now. I was clueless, you may have saved my life...or my pool's life ;) ♥️
ChristopherDB
In The Industry
Apr 21, 2021
63
Florida
Jandy Aquapure 1400
I second this. Best to replace. About 15 years ago I had a filter explode while pressure was building and almost lost my thumb. Tore it in half, bone sticking out. Not a fun ride in the ambulance and I never gained full movement back.
