drharris
0
So I ordered some of these and when I put them on, I started getting air bubbles in my returns. I removed the hairnet off just one of the skimmers and it stopped. I'm guessing that means I have a very small leak on the suction side and the hair nets are causing the pump to suck harder and exposing the leak? Any other thoughts or anybody else have this problem?
I'd suspect a small leak somewhere, but finding it will be a pain. Do you have valves on your suction side for the main drain and skimmer? You could try increasing the flow from the main drain or else decreasing from the skimmer side. Either way, the pump won't be pulling as much from the skimmer side.
