- May 19, 2021
- 45
- Plaster
- Jandy Truclear / Ei
Spa only ever had 4 jets or returns in it and we had them rebuild the wall between the pool and spa and add in two more for a total of 6.
When you remove the return wall fittings you have these long cone shaped items that screw in. 4 of them are the old ones with small holes and the two new ones have larger holes. I do not know what these parts are called and looking for some help so that I can replace them. I can see that the new one has a larger thread size than the old ones so will not be able to use the same one in all 6 of them.
